Activity Forums Adobe After Effects Cast shadow from keyed footage on CG environment
  • Cast shadow from keyed footage on CG environment
    Posted by Joakim Norberg on September 25, 2009 at 5:27 pm
    Hi.
    I got this keyed RED-footage of a woman running in slow motion while the camera is moving. The footage is camera tracked and imported into AE. So i got a camera setup that matches the footage perfectly.
    How can I use the built in light system in AE to cast shadows from the woman to the cg environment? If I turn the footage into a 3D-layer with the orient towards camera on, the camera solve doesn´t work anymore.
    Is there a solution for this, or another teqnique i can use? Im confused.
    Joakim Norberg replied 16 years, 11 months ago 2 Members · 2 Replies
  • Scott Novasic
    September 25, 2009 at 9:49 pm
    not sure why you would need to use the 3d camera for this. I would use any number of shadow techniques, given that you have a mask. which is the hard part with live action content
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Joakim Norberg
    September 28, 2009 at 6:36 am
    This is what i got:
    – Footage that include a woman running in slow motion and a moving camera.
    – Tracked and solved 3D environment exported into AE. (flawless)
    Now i want to add the environmen, in this case just a floor.
    My problem is to get shadows from the actor on the floor i created in AE.
