Activity Forums VEGAS Pro “Casino” Effect
  • “Casino” Effect
    Posted by David Aman on January 15, 2009 at 6:20 am
    I’m trying to get the time lapse transition fades that they have in the movie “Casino”; when the guy gets out of the car and is greasin palms. there’s something i’m missing – i cut some of each clip and do a crossfade. i know there’s something else in there i gotta do, but what it is..
    David Aman replied 17 years, 8 months ago 3 Members · 3 Replies
  • Craig Patterson
    January 15, 2009 at 2:21 pm
    Can you give us more info on why it doesn’t look right? I’m not sure if I recall that scene, but I think it also used a flash as a transition between clips, rather than just a fade.
    http://www.pmerecords.com
    http://www.sarahburgessmusic.com
  • Graham Bernard
    January 15, 2009 at 3:56 pm
    I don’t have the DVD to refer to. If you have a link to what you are referring to I could have a “stab” at a solution?
    In the meantime, have a look at transition envelopes. This function allows us to sustain, hold or even REVERSE a transition effect. It works in a similar way as a velocity envelope.
    Grazie
  • David Aman
    January 16, 2009 at 6:52 pm
    o.k., i’m going to try to pull it off the web somewhere. if not, i’ll get the dvd and pull the clip. thanks!
