Activity Forums Adobe After Effects Cash Register numbers(why the jitter?)
  • Cash Register numbers(why the jitter?)
    Posted by Scotty Pupkin on May 6, 2009 at 6:06 pm
    Hi
    I was given a project where I have to animate digital numbers in a cash register window—from 0.00 to 7.00.
    I created a black solid and applied the “numbers” application (under text) and it’s pretty much what I was looking for…..except: I am getting a jittery effect when it “jumps” up every dollar value. From 0 to 1 to 2 to 3 etc….there’s a BIG jitter jump. Seems like the numbers on the right side of the decimal are fine.
    Can anyone help?
    It’s appreciated!!!
    Scotty
    David Bogie replied 17 years, 4 months ago 2 Members · 5 Replies
  • David Bogie
    May 6, 2009 at 6:38 pm
    “big jitter jump” is not illustrative in the least. the chroma flies off the vector? The scale changes? The dimensional position changes? You must use a monospace typeface.
    bogiesan
  • Scotty Pupkin
    May 6, 2009 at 7:06 pm
    Hello again
    I tried a monospace typeface–courier font–which helps w/ the number shifts but the entire number(as a whole) is moving frantically as if a earthquake/jitter effect was applied.
    It’s as if I gave it a wiggle–it’s slight but very noticeable.
  • Scotty Pupkin
    May 6, 2009 at 7:09 pm
    I think I figured it out–I clicked “proportional Space” OFF….that took care of it I think.
    thanks
  • Scotty Pupkin
    May 6, 2009 at 7:14 pm
    thanks bogiesan
    Ok by jitterjump I really meana “shift” in position by the dollar value…actually, watching it again, it’s as if the entire numerical “block” has a frantic wiggler effect.
    I’ll try the monospace typeface.
    thanks again–appreciate it!
  • David Bogie
    May 7, 2009 at 3:12 pm
    Thanks for closing the thread with a viable solution.
    Hardly anyone does that around here.
    bogiesan
