Activity Forums VEGAS Pro cascading or bullet point titles in Newblue Titler in Vegas
  • cascading or bullet point titles in Newblue Titler in Vegas
    Posted by Gary Abraham on May 13, 2013 at 9:35 pm
    John Rofrano has a video showing how to do cascading titles in Pro Type Titler. I want to do something similar in NewBlue Titler.
    Can anyone help? John, have you used Newblue Titler? Can you help?
    Regards,
    Gary Abraham
    Norman Black replied 13 years, 3 months ago 2 Members · 3 Replies
  • Norman Black
    May 13, 2013 at 11:10 pm
    If you are talking about having a line at a time fade in, then use the Fade in transisition. Set apply to Line. Then maybe set overlap to 0, or just play with the params to get what you want.
    The Titler transisitions can apply per letter, per word, per line or per paragraph.
  • Gary Abraham
    May 14, 2013 at 6:56 pm
    Hi
    Thanks for responding. I know how to that with individual paragraphs.
    What if I have a list of 8 lines to bullet point one at a time.
    Is there a way to copy/paste the list and then time the fade in of each one without doing them individually?
    Just curious.
    Gary
  • Norman Black
    May 14, 2013 at 11:29 pm
    If your paragraph consists of 8 lines of text, you do exactly as I said. Set fade in to apply on a line by line basis. Fade in can operate on a letter, word, line or paragraph basis.
    Example steps;
    Enter your paragraph. 8 lines in your case.
    Go to transistions, select the fade in transition, click and drag the fade letters preset to your paragraph.
    Now change “apply to” to “line”
    At this point you will/may want to adjust the overlap and smoothness settings to taste.
    If you have multiple columns, you have to use a paragraph for each and stagger the start point of the second paragraph fade in.
