Activity › Forums › Adobe After Effects › Cartoon Shading in New AE 7?
Posted by Cowrob on January 29, 2006 at 10:53 pmQuick question on a new capability I was advised is in After Effects 7.
Specifically . . . transforming regular video into cartoon shading. Specifically, simplifying the shading to something resembling:
The movie
Cowrob replied 20 years, 7 months ago 5 Members · 6 Replies -
Mylenium
January 30, 2006 at 6:09 amDunno what DA told you exactly, but you could use the new timewarb tool to smooth your footage out and then massage it with other filters.
Mylenium
[Pour Myl
Mike Clasby
January 30, 2006 at 6:52 amThey might mean the new Smart Blur filter. It’s an integral part of my favorite Photoshop Action, “Lawtoon”. Bt Lawtoon (available at Adobe Studio Exchange) uses “Paint Daubs”, Accent Edges” and “Diffuse”, none of which are on AE.
Barend Onneweer
January 30, 2006 at 8:09 amThe examples you give are a lot more manual work than just a filter on top of your video.
But I haven’t got a clue what Digital Anarchy was hinting at when they said that there was already ‘toon’ functionality in 7.0. Not that I know of anyway.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Tim Kurkoski
January 30, 2006 at 10:28 pmI’ve played with using Illustrator CS2’s LiveTrace feature to sort of do this. Only problem is the batch feature for Illustrator limits you to 10 files at a time. You have to hack the script file used by Bridge to up the max number.
Go to this folder: C:\Program Files\Common Files\Adobe\StartupScripts\LiveTrace_AI.jsx.
Open LiveTrace_AI.jsx.Change the following two lines:
var MAX_BATCH_SIZE=10;
to
var MAX_BATCH_SIZE=99999;scpt += ‘var doc = app.documents.add();\r’;
to
scpt += ‘var doc = app.documents.add(DocumentColorSpace.RGB);\r’;(This second one defaults it to RGB, which you’d otherwise have to do from within Illustrator.)
Then you simply select your source images in Bridge and choose Tools > Illustrator > Live Trace.
Cowrob
February 2, 2006 at 10:59 pmThanks for the terrific reply . . . just one issue . . . I’m on a Mac, and looks like you’re on a PC.
Is there a similar script fix for Macs?
Rob
