Activity › Forums › Apple Final Cut Pro Legacy › cartoon look
cartoon look
Posted by Rap on October 7, 2007 at 7:22 amHello everybody
I am trying to add a “waking life” look to my project and I found “line art” effect in FCP effects but that is very limited, is there any other effect I can use? download maybe (free!)thanks for any suggestions
John Wiedenheft replied 18 years, 11 months ago 6 Members · 6 Replies -
Shane Ross
October 7, 2007 at 8:30 amhttps://straylight.tv/pluginz/index.html
Graphic Novel Look. Close…
Waking life was frame by frame painstakingly assembled.
Shane
Littlefrog Post
http://www.lfhd.net -
Chris Poisson
October 7, 2007 at 2:53 pmToonit can be very close if you take the time to learn it and tinker with it, but be ready for some LONG render times. I mean REALLY long, like days.
Have a wonderful day.
Shane Ross
October 7, 2007 at 3:49 pmToonIt is too expensive for what it does. You’ll get a better result from the Graphic Novel Look, and it is cheaper.
Yes, I have tried both.
Shane
Littlefrog Post
Tim Ward
October 8, 2007 at 6:10 amThis doesn’t involve FCP per se, but another way uses After Effects and Illustrator CS2 and up. It involves creating a sequence of stills, using Live Trace in Illustrator to create the vector images, then rebuilding the sequence in AE (or FCP).
The Cow’s Aharon Rabinowitz has a 2-part video podcast on the process:
tim
John Wiedenheft
October 8, 2007 at 3:30 pmhttps://www.dv-forums.com/forums/showthread.php?t=260
The post here goes through a couple of processes, including Aharon’s tutorial. Though it mostly covers the same as talked about above.
