Activity Forums Adobe After Effects cartoon lemon explosions
  • Ryan Hill
    March 22, 2006 at 3:07 pm
    Try a bulge distortion on the lemon just shortly before it bursts, and maybe continue expanding it during the shatter. Try putting it both above and below the shatter effect to have them interact differently.
  • Aharon Rabinowitz
    March 22, 2006 at 3:28 pm
    Try using roughen edges which sort of dissolves things from their edges.
    Also, you could try shattering the already shattering lemon (Add a second iteration of the same effect).
    You could also do the effect and then render that out and then use the cartoonification process I describe in this (long) tutorial, so that it gets a cartoonish look:
    https://www.creativecow.net/articles/rabinowitz_aharon/cartoon_look/index.html
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Criis Daw
    March 22, 2006 at 3:34 pm
    Again thanks for advice..
    I am working on it right now so will give it a try….
    Its days like these that a love working in after effects..
    the problem solving and people giving there advice
    I love it
    GEEK OUT
    love ya
  • Criis Daw
    March 22, 2006 at 4:21 pm
    In case you’re following this I have found that by duplicating the original explosion layer 4 times and offsetting each layer by one frame and making the dupes progressivly smaller i get a really nice looking explosion with “juice’ trials. If i then pre comp this and then roughen the edges the expolosion really does start to look friuty.
    Will try this cartoon tutorial on it now and see if the desired look can be acheived…..
    Thanks you all
  • Aharon Rabinowitz
    March 22, 2006 at 4:30 pm
    I’d love to see it when it’s done. Will you be able to post it, or is this one of those things that you can’t share becasue it for a client?
    Thanks.
    Aharon
    Aharon Rabinowitz
  • Criis Daw
    March 22, 2006 at 4:32 pm
    Yeh I can share it….
    like i said the project has been postponed its just i know it will need exploding lemons and strawberries..
    At this stage its all mine
Page 2 of 2
