Activity Forums Apple Final Cut Pro Cartoon effect question
  • Cartoon effect question
    Posted by Darren Martin on December 7, 2017 at 8:41 pm
    Hey guys, just wondering if anyone knows how to achieve a cartoon effect like this, is this rotoscoping and does it involve a lot of time drawing each keyframe or is there a paid plugin that would achieve something similar. It will be for a music clip and i need to give them a price, i know bands don’t have much money so the cost of me drawing each frame is going to blow the budget out.
    https://www.youtube.com/watch?v=2C0OEVWKZv0
    Darren Martin replied 8 years, 8 months ago 3 Members · 4 Replies
  • Jeff Kirkland
    December 7, 2017 at 10:48 pm
    I’d say the only way to get an effect as clean as that is to rotoscope. Any plugins I’ve tried to produce that effect tend to be a bit hit and miss and just look like a badly posterised photo. The cartoon plugin in Resolve is actually pretty good and might get you close – or you might look at some cartoon/comic book actions for Photoshop (which people often forget can process video as well). But even with a plugin to automate it there would be a lot of clean up work to get it to the level of that sample video so it’s still not going to be cheap.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Mark Suszko
    December 8, 2017 at 8:50 pm
    My take on this is, it’s a multi-step process, but doesn’t necessarily require roto. A lot of time color grading, but not really “roto” in the Ralph Bakshi sense.
    If the talent wears chroma blue and chroma green, that can help, but what I see here are two main effects; the final one is a posterization or solarization effect with the bit depth turned way down. But before I would apply that, the raw video needs to be simplified, that’s where the keying comes in. It reduces greatly the need for roto if you have a keyable background, and clothing that is a different color than the background yet also keyable. And some of that, you can change around by first doing some passes thru color re-timing, to reduce the overall number of color shades and enhance the contrast. Then you posterize the final comp. Tri-tone effect might also help. Bret FX, Motion VFX, and a few others have plug-ins to get there faster, but you certainly could make these FX from “scratch” as well.
  • Darren Martin
    December 27, 2017 at 6:11 am
    Thanks so much for your detailed response, that was quite helpful!
  • Darren Martin
    December 27, 2017 at 6:12 am
    Yes i thought that might be the case, thanks a lot for the advice 🙂
