Activity Forums Apple Final Cut Pro Legacy Card to go with HD Connect LE and FCP in G5 Powermac
  • Card to go with HD Connect LE and FCP in G5 Powermac
    Posted by Nigel on July 7, 2006 at 9:48 pm
    I’m shooting footage on JVC GY-HD101E, then will be editing in FCP (latest version), but am interested in buying a Connect LE so I can feed the 720/25p footage though it so it comes out of the SDI/SD into FCP as SD footage with I-frames on every frame.
    I’m assuming if I intend outputting an SD DVD via DVDSP3 then the Connect LE and this workflow is the way to go?
    But I understand I’ll need a G-Raid 500GB drive that has two 250GB drives raided together so my dual 2gig G5 will be able to handle this new SDI/SD footage, is this right? at the moment I have two internal 500GB 7200 drives and two external FireWire LaCie 250gig drives.
    I also understand I’ll need a special card in my Mac to get from the Connect LE into Mac, somebody said Blackmagic? any advice on what the cheapest card available is would be appriciated.
    I only intend shooting 720/25p from the JVC in HDV mode and putting that into FCP via either SDI/SD, or SDI/HD (when HD DVD players are more readily available in the future).
    Please advice on if I need the G-Raid hard drive and what card I will need to go with Connect LE.
    Oh, finally, if I need G-Raid, can I still back up my project, complete with movie files to my LaCie hard drives?
    Nigel replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
