Activity › Forums › Maxon Cinema 4D › card attached to balloon string through xpresso won’t fix on string point? (file included)
  • card attached to balloon string through xpresso won’t fix on string point? (file included)
    Posted by Daniel De silva on November 12, 2015 at 12:59 pm
    Hey guys,
    I need some fast help if possible!
    As can see attached in the scene, I have a card attached to a balloon string using xpresso, string is dynamic.
    When still the card remains intact with the string end point, however when moving it moves itself a few places down for reasons which I can’t seem to see?
    Anyone have any solutions?
    9451_forsolve.c4d.zip
    Dan.
    Daniel De silva replied 10 years, 10 months ago 3 Members · 4 Replies
  • Cassius Marques
    November 12, 2015 at 1:25 pm
    Just baking the dynamics then caching the spline dinamycs seems to solve the issue. Have you tried that?
    Cassius Marques
    http://www.zapfilmes.com
  • Daniel De silva
    November 12, 2015 at 2:23 pm
    Genuis! I’m new to dynamics so wasn’t sure what the issue was, speaking of what was the actual issue here?
    Dan.
  • Brian Jones
    November 12, 2015 at 3:07 pm
    Priority of the XPresso is too low (early) it’s getting evaluated first – it’s moving the tag to where the string is at the calculation phase of the frame – then the balloon gets moved by the dynamics later in the calculation phase, then it renders so the tag is always a frame behind. If you increase the Xpresso priority to a higher value (calculates later) than the dynamics the xpression will calculate after the dynamics and follow the balloon. Dynamics priority is Generators +400 so the XPresso has to be Generators +401 or higher.
  • Daniel De silva
    November 16, 2015 at 12:11 pm
    amazing thanks so much this worked also!
    I have a follow up question with another issue I am experiencing, after the simulation ends, from frame 300+ I have a slight jitter on my spline dynamics that I don’t want in the scene as the camera will be in on a close up to read text on the card, how can I get rid of ths?
    I’ve attached the files for you to see what I mean!
    9460_balloonjitter.c4d.zip
