Try 4:2:2 instead. About the only situation where you’ll see a difference in the picture quality of your shoot in HQ is if there is a lot of fast movement from frame to frame… sports for example. Otherwise it would look exactly the same and you only gain file size.
ProRes LT is a good option for most jobs quite frankly. It’s broadcast quality, but not good for material with a lot of detail in it like outdoor shots of pine trees and grass etc…
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
