Activity › Forums › Avid Media Composer › capturing with 4 frame offset – possible?
  • capturing with 4 frame offset – possible?
    Posted by Justin Tan on May 21, 2007 at 2:09 am
    Can anyone help me? I am trying to do a capture (via SDI), but because external processing deck to processor to Avid, I have a 4 frame delay.
    I know that in FCP & Smoke, you can set capture offsets, but I can’t seem to find the option in the AVID.
    I have an Avid adrenalin HD if it matters.
    Beacuse of various reasons, I am un able to edit the TC of the clips.
    Any thoughts or suggestions would be very much appreciated.
    Grinner Hester replied 19 years, 4 months ago 4 Members · 5 Replies
  • Terence Curren
    May 21, 2007 at 4:09 am
    Look in the deck configuration window.
    Terence Curren
    http://www.alphadogs.tv
    http://www.digitalservicestation.com
    Burbank,Ca
  • Justin Tan
    May 21, 2007 at 9:09 am
    I have with no success unfortunately – there are offsets for audio but not timecode
  • Michael Hancock
    May 21, 2007 at 12:20 pm
    [justin] “Beacuse of various reasons, I am un able to edit the TC of the clips.”
    What are the various reasons you can’t change the TC? Is the Avid not allowing you to? Once you capture a clip, you can change the timecode, but you have to unlink it first, then select the clip–right click, modify, change the offset (it will give you a lot of warnings about how dangerous this is), then relink. It should work.
    Michael.
  • Justin Tan
    May 21, 2007 at 1:17 pm
    Sorry should have explained myself more… Reason for not being able to change the TC is more practical than technical. As things are being captured on a daily basis by multiple persons, I wish to avoid the need to change the TC of clips before and after capture. It may be a last resort, but is definately something I wish to avoid.
  • Grinner Hester
    May 22, 2007 at 4:37 am
    you can alway lay these clips on their own timeline and deignate that timeline’s tc. You can use these as a source.
