Activity Forums Adobe Premiere Pro Capturing Video using PP2
  • Capturing Video using PP2
    Posted by Will Gaffney on May 27, 2006 at 8:06 am
    I have just started using PP2 and only a moment ago attempted to capture my first lot of footage from my Sony HDR-FX1. I connected the iLINK cable to the PC and then to my camera and was prompted to capture using PP2. I clicked on that and the capture screen opened, but would not let me record. All it says is “Cannot activate recorder, try resetting camera”. The computer is definately linked to the camera as I can still play/rewind/ffd etc using the computer, however the image does not come up on the screen and I cannot record. I tried switching the camera on and off, resetting the computer, did a full reset of the camera and still nothing. Am I doing something wrong, or is this a fault with my camera or PP2?
    Andre Gagnon replied 20 years, 3 months ago 6 Members · 14 Replies
  • 14 Replies
  • Craig Howard
    May 27, 2006 at 8:49 am
    Is the camera in VCR mode ?(not camera mode)
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Will Gaffney
    May 27, 2006 at 9:38 am
    Yes I have tried in both VCR and record modes…
  • Roger Averdahl
    May 27, 2006 at 10:10 am
    Go to Project > Project Settings > Capture and make sure that Capture Format matches the video format you want to capture.
    /Roger
    Premiere Pro User Group Sweden – http://www.pproug.se
  • Will Gaffney
    May 27, 2006 at 10:33 am
    Just tried that now, and it was already set on the right settings.
  • Roger Averdahl
    May 27, 2006 at 10:51 am
    Here are some more tips: Can’t activate recorder. Try resetting the camera.
    /Roger
  • Will Gaffney
    May 28, 2006 at 2:03 am
    Tried everything in that list and nothing worked…
  • Scottsdigitalphoto
    May 28, 2006 at 1:20 pm
    I am having the same exact problem with my Sony Z1U.
    I have not figqured out how to get the capture deck to work. My deck is black, yet the controls work, like in your case, and I keep getting reset the camera message. Maybe there is a major software interface problem here.
    May 28, 2006 at 1:23 pm
  • Richard Evans
    May 28, 2006 at 7:37 pm
    I’m currently using PP2 and the Sony Z1, and I’m having no problems at all. What are your settings in PP2? I’ll compare them to what I’m doing and maybe we’ll find a problem.
    Richard
  • Will Gaffney
    May 29, 2006 at 12:35 am
    I have actually uninstalled PP2, re-installed PP1.5 which I have been using for the last 6 months, and I am having the same problem.
    The only other thing that I changed at the time of upgrading to PP2 was I also upgraded windows to XP SP2 as PP2 is not compatible with SP1. Is it possible that my capture card is not compatible wih XP SP2?
