Activity Forums Adobe Premiere Pro Capturing Video using PP2
  • Richard Evans
    May 29, 2006 at 3:00 am
    A capture card really isn’t necessary for capturing DV/HDV footage. All you’ll need is a firewire port and cable. Sounds like you have a conflict in settings with premiere and your camera. Just make sure you have the right presets and the right device control.
    Richard
  • Roger Averdahl
    May 29, 2006 at 12:18 pm
    I just found a solution in Adobe’s forum: Create a new User Account with administrative privileges in Windows and capturing should work again. Even if your old User Account have administrative privileges creating a new one is worth trying. 🙂
    Dont forget to log into the new account!
    /Roger
    Premiere Pro User Group Sweden – http://www.pproug.se
  • Will Gaffney
    May 29, 2006 at 11:17 pm
    I have figured it out! It seems that for some reason my external sound card and its drivers were clashing with PP2. So I formatted my PC, turned on my on-board sound card in the bios, re-installed XP SP2 and all the standard essential drivers, then just installed PP2, and it all works perfectly.
    Now all I need to do is figure out how to re-install my external sound card so I can start using Pro Tools again.
    Any ideas?
    Thanks to everyone for upir help so far…
    Will
  • Andre Gagnon
    May 29, 2006 at 11:31 pm
    First disable the onboard sound card in the BIOS of your system. Then reboot and install your PCI soundcard in a free PCI slot on the motherboard. Finally, install the drivers supplied by the manufacturer of this souncard for this particular device.
Page 2 of 2
