Capturing video using HDMI instead of Firewire
Posted by Mike Semanoff on August 13, 2010 at 10:47 pmMy firewire port is getting wore out and doesnt stay connected reliably. I want to use my HDMI port on my Sony V1U to capture my video instead of the firewire port. I have HDMI imput on my computer and Vegas 9 Pro installed. What else do I need to be able to capture tapes using the HDMI port?
Danny Hays replied 16 years, 1 month ago 3 Members · 6 Replies -
Danny Hays
August 14, 2010 at 3:25 amBlackmagic makes a HDMI, component, s-video and composite capture and playback, preview card and usb 3 device, both cost 189$ each. BUT you have to have a quad core with an X58 chipset for it to work.
I built an I7 and bought the USB 3 Shuttle. It works great. It can capture straight from the imager of my HDV camera and bypass the M2T compression. Captures in Blackmagic Motion JPEG and 8 and 10 bit uncompressed if you have a raid 0 array to handle the I/O. Check them out.
https://www.blackmagic-design.com/products/intensity/ -
Mike Semanoff
August 16, 2010 at 5:01 pmThanks Danny. So I need a quad core with an X58 chipset even if I am not capturing live footage straight to the PC? I generally have to record to tape in the field then capture at home.
Danny Hays
August 16, 2010 at 6:29 pmThis will still work like that, but you will be capturing the same format as is you were capturing through the firewire. The main reason I got it was live out of most cameras HDMI, DV, HDV is it bypasses the HDV, DV compression and can get better quality straight from the camera imager, instead of DV or HDV. If it captured to tape, then it’s already compressed. Live from the camera component, HDMI or composite, S video is it’s captured before the camera compression, and can be captured as Blackmagics MJPEG or 8 and 10 bit uncompressed avi, but the uncompressed video capture will need a fast RAID array to get that much data in and out in real time.
Stephen Mann
August 18, 2010 at 1:47 pmI am considering exactly this setup for my greenscreen studio. I am already capturing live to my PC in HDV, but I am not getting as clean a key as I would like because of the compression in the camera.
What RAID do you recommend? What’s your workflow into Vegas?
TIA
SteveSteve Mann
MannMade Digital Video
http://www.mmdv.com -
Danny Hays
August 18, 2010 at 4:18 pmI,m using Motion JPEG wich doesn’t need a raid. I don’t use Vegas for my keying as there is no spill supression. I use Ultra 2 or Keylight in After Effects to key, then bring into Vegas to arange. The best way I know to get a real looking key, with great shadows is Keylight. Check out this video tutorial. This keylight pluggin can be used in the timeline and seveeral instances of it too. Very slow to preview but with practice, it can look very real. Danny
Also the Blackmagic MJPEG keys very well as it’s an avi, not mpeg.https://www.videocopilot.net/tutorials/3d_shadows/
Danny Hays
August 18, 2010 at 8:13 pmThat tutorial was for shadows, Here’s the one for Keylight.
https://library.creativecow.net/articles/kramer_andrew/colorkey.phpAs far as workflow, that changes depending on if I need to put the same subject in the video twice or more.
Also if you have alot of space and alot of good lighting,if you know how to backlight and eliminate spill, and don’t need shadows, you can use the chromakey pluggin in vegas. Danny
