Activity Forums Apple Final Cut Pro Legacy Capturing Video live (in real time) straight into FCP
  • Capturing Video live (in real time) straight into FCP
    Posted by Beau Brotherton on January 29, 2009 at 9:09 pm
    Hello to all,
    I have a project in the mix for a local church in my area. They are just now getting into wanting to shoot and edit their sermons, and make DVDs and online video. They have asked me to help them out this Sunday to show them how to shoot the sermon and the basics of editing. But, once they know the basics, I will shoot for them and let them edit their sermon.
    My question then is…… Is there a way to capture live/streaming/real time video straight from a Panasonic HVX200 into FCP. Again, they have no idea how this works, and I have agreed to shoot on Sundays, and let them edit. But, of course they don’t have a deck or other camera, so how do they capture? I of course have told them that I can’t/won’t use my camera as a deck. So what they asked, was can we go straight into the mac from the camera through firewire?
    Is this possible? If so, what would I/they need? I know that I could use my camera in P2 mode and get 63 min or so on my 16gig card, but I still would have to stay around while it transfers. I would love to bypass this if possible. Our dream situation would be I…..
    -Set up the gear (camera to mac through firewire)
    -Record the sermon (while capturing in Final Cut)
    -Pop out the tape and give it to whomever
    -Pack up the gear and go home
    That’s it. Again, is this possible??
    Thanks for your help! 🙂
    Beau Brotherton
    Macbook Pro 2.4GHz, Intel Core 2Duo, 4GB
    FCP6
    HVX200
    Dave Pickell replied 11 years, 11 months ago 7 Members · 7 Replies
  • 7 Replies
  • Mike Johnson
    January 29, 2009 at 9:22 pm
    It is possible to capture a live feed from a camera straight into FCP via FireWire. I don’t see any reason why the HVX200 wouldn’t be able to do this, but you may not be able to go HD.
    After hooking up your camera to the computer, start FCP and go to the Capture dialog. In the Capture Settings tab, change Device Control to Non-Controllable Device. Then just use the Capture Now feature to capture the live feed from the camera. You might want to double check your user prefs to make sure there is not a limit set on capture now, otherwise FCP will stop the capture after a set amount of time.
    Mike Johnson
    Final Cut Pro Editor
    Drury Outdoors
    http://www.druryoutdoors.com
    View Mike Johnson's profile on LinkedIn
  • Beau Brotherton
    January 29, 2009 at 9:36 pm
    Sweet!! Thanks Mike, I’ll give it a shot tomorrow. I’m so glad that was easy! 🙂
    Beau Brotherton
    FCP6
    HVX200
  • David Bogie
    January 29, 2009 at 11:51 pm
    Most deities can’t be bothered with mean time to failure specifications or boobies who trip over cables. Be sure you are also rolling tape.
    bogiesan
  • Rafael Amador
    January 30, 2009 at 1:58 am
    You Don’t need even FC.
    Just plug the FW to the Mac and in QT “Open a new Video Recorder”.
    rafael
    http://www.nagavideo.com
  • Greg Ball
    February 4, 2009 at 10:57 pm
    I have someone asking about capturing a 2 camera shoot (sony Ex1’s) into a switcher with audio and capturing the outputs of the switcher and audio right the FCP Live Is this even possible?
  • Willy Lavendel
    February 4, 2011 at 9:41 pm
    Hi all,
    I will be doing the same thing as mentioned but using the canon XH-A1, I just want to be clear that it will simultaneously be recording to tape AND through QT.
    Willy
    Willy Lavendel
    “Is this for real?” “No, only in the movies”
  • Dave Pickell
    October 4, 2014 at 11:46 pm
    Hi, on my macbook pro, with a Canon Zr 800 firewired in, import fcp shows two cameras…the ‘facetime’ one in the macbook and the canon. Select facetime, import (capture) streams seamlessly. Clip is in main window when i close import screen. Select zr800 and all seems normL except there is no clip waiting when i close the import screen. Any clues? Thanks,
    Dave
