Activity Forums VEGAS Pro Capturing Video in Vegas
  • Capturing Video in Vegas
    Posted by Jeff Carpenter on August 22, 2009 at 4:56 pm
    I have a JVC MiniDV camcorder with a bunch of different clips on the tape, but when I capture in Vegas, it all comes across as one large clip and then I have to go through and separta each clip manually. Is there a setting that will do this for me automatically while capturing? Thank you in advance
    Mike Kujbida replied 17 years, 1 month ago 2 Members · 1 Reply
  • Mike Kujbida
    August 22, 2009 at 5:12 pm
    In VidCap (the capture utility), Options – Prefs – Capture.
    Make sure that Enable DV Scene Detection is selected.
    If it is, that means one of two things.
    #1. The time & date aren’t set in your camcorder (this is where time code is derived from);
    #2. The internal battery needs to be changed (life expectancy is about 5 years max).
