Activity › Forums › Apple Final Cut Pro Legacy › Capturing VHS/SVHS to Final Cut Pro via other decks for TBC.
  • Capturing VHS/SVHS to Final Cut Pro via other decks for TBC.
    Posted by Chris Tomkins on November 16, 2010 at 4:52 am
    Hi all
    First up, please let me assure you I have tried to find some answers here and on other forums – I understand this question gets asked a lot, but I have a twist on it.
    I have several VHS/SVHS tapes I need to capture. They are of varying quality.
    I have a pro SVHS deck with SVIDEO out, which I am running directly through my Panasonic camcorder to FCP – pictures come through fine and I can use capture now…
    However, I am having a lot of trouble with the audio going out of sync when there is a dropout. I understand this causes timing problems and I need a Time Base Corrector.
    The guy who own the edit suite I work in said I should run the video through their Digi Beta deck or DVCPRO 50 deck.
    When I do this (via composite inputs) the DVCPRO 50 deck picture flashes green every few seconds, and the DigiBeta deck does a really slow “roll” creeping up a pixel at a time every few seconds.
    Is there something else I should be doing here? Should I be trying to feed the TC-OUT from my SVHS deck to these other decks? Or the SVHS deck has a SYNC output – does that do anything?
    Any suggestions?
    Cheers
    Chris
    Chris Tomkins replied 15 years, 10 months ago 2 Members · 2 Replies
  • Bj Ahlen
    November 16, 2010 at 4:48 pm
    I didn’t think there were any SVHS decks without TBC, but then I recalled there were actually less expensive decks that cost a few hundred instead of the $1800 I paid for my AG-1830 SVHS deck back in 1998.
    You did adjust the tracking, right? That sounds like it could be your first problem.
    Find a post outfit that can do the transfer for you, shouldn’t cost much.
    Then you would get the TBC and a 4:2:2 transfer to say DVCPRO50 instead of the miserable 4:1:1 (DV25 I presume) through your camcorder.
    A post house may also have a deck with better heads that can pick up poor tapes better.
  • Chris Tomkins
    November 18, 2010 at 1:40 am
    Hi – thanks for replying. Yeah I’m adjusting the tracking – unfortunately these are family videos and there is about 200 hours of footage and I have no budget. I’m not wanting to edit them into anything, just to protect them from tape degradation over time.
