Activity › Forums › Blackmagic Design › Capturing SDI can you record only 2 audio ch’s?
  • Capturing SDI can you record only 2 audio ch’s?
    Posted by Jason King2 on June 12, 2006 at 5:40 pm
    Hello,
    I posted earlier about wanting to capture only 2 ch’s of audio in the analog composite mode in FCP, so I turned off the little speakers in the log and caputure window and this works fine. But now when I capture SDI with only the first two speakers selected I get 4 chs of audio. Is there something else I need to turn off in SDI mode to get only 2ch’s of audio? I read through the entire manual but can’t find a directive on this.
    Jason
    Kaspar Kallas replied 20 years, 3 months ago 2 Members · 1 Reply
  • Kaspar Kallas
    June 15, 2006 at 3:55 am
    Hi
    in thw window where are the sound channels there is also a scrollbar so scroll it down and switch off the remaining ch 11&12
    happened to me once or twice
    -Kaspar
