Activity › Forums › AJA Video Systems › Capturing SD to ProRes
  • Capturing SD to ProRes
    Posted by Chris Mushinskie on June 23, 2010 at 9:15 pm
    I’d love to be able to digitize footage directly into Final Cut as Pro Res. I thought I would be able to do that with my Kona2. I’m just digitizing SD material from a beta. I select AJA Kona 2 – NTSC Apple ProRess 422 as my Easy Setup. When I go to capture, it still captures everything as Uncompressed. (Despite the fact that under Audio/Video Settings it reads “AJA Kona2: 525 29.97 Apple ProRes 422”.
    When I look at the capture presets it reads under Quicktime Video settings: Digitizer: AJA 10-bit Digitizer, Compressor: Uncompressed 10-bit 4:2:2. However in the summary area it says “Apple ProRes422 at best quality”
    If I change the Digitizer to ProRes I get an error message when I try capturing.
    I’m not sure what I am doing wrong.
    Any ideas?
    John Pale replied 16 years, 3 months ago 4 Members · 5 Replies
  • Gary Adcock
    June 23, 2010 at 9:34 pm
    The kona 2 is a pci/x bus card, you can only capture as ProRes on an intel computer, and the intel machines are all pcie as far as I know.
    What computer are you trying to capture on?
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Technology Development
    Quality Assurance Assistance
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Chris Mushinskie
    June 23, 2010 at 10:21 pm
    Yeah my system is a dual 2.5 Ghz G5. I knew that capturing HD resolution footage as ProRes on a PowerPC was not an option, but for some reason I thought I would be able to capture SD footage directly as ProRes.
  • Eric Sternberger
    June 24, 2010 at 3:02 pm
    Actually you can capture ProRes with a G5. We have a dual 2,3 Ghz Model with a Lhe and do that all the time. But we only use it for capturing Digi-Beta SD-Stuff to ProRes (SQ)
    However the G5 is probably too slow to capture HD in ProRes with the AjA board, though I never really tested it. (But it works over firewire for HDV sources)
    But I´m not sure about the Kona 2. Does it really support ProRes?? You probably then have a PCI-X machine as Gary points out. Not sure about that, but our “late” G5 PCIe-Model does the Trick 😉
  • John Pale
    June 27, 2010 at 10:42 pm
    Not sure what the problem is, but you can MOST DEFINITELY capture and edit with ProRes in SD on that machine. My previous computer was a Dual 2.0 and I did it all the time before upgrading to a Mac Pro. HD is a total no-go, but SD worked fine.
  • John Pale
    June 27, 2010 at 10:43 pm
    And yes, I had a Kona 2
