Activity Forums Apple Final Cut Pro Legacy Capturing problem
  • Sascha Engel
    May 19, 2010 at 4:55 pm
    Please, try to specify the problem a bit further – do you batch the time codes first and then batch capture it all together?
    What is the capture settings? What scratch disc did you define – internal or external?
    Did you in the preferences adjust the pre- and post-roll settings for capturing?
    Try to be a detailed as possible.
    Thanx.
    Sascha
