Activity Forums AJA Video Systems Capturing PAL / with deck control
  • Capturing PAL / with deck control
    Posted by Steve Radley on June 26, 2006 at 5:15 pm
    I am capturing in FCP Composite PAL uncompressed 8-bit from an NTSC to PAL converter, playing back from an NTSC Digibeta machine with a tape that has non-drop timecode, patched composite into the converter. I am doing this successfully with the io deck control set to non-controllable device and just manually pressing play on the deck. I did a test changing the deck control to RS-422 NTSC and the PAL capture seemed to be fine. I would love to be able to Batch Capture with deck control. Will my clip eventually be out of sync somehow with my 25 fps sequence if I capture with RS-422 NTSC control? Does the RS-422 NTSC control non-drop timecode get captured with the PAL signal, or is non-drop code, non-drop code no matter what the frame rate the clip is?
    Steve Radley
    Digitec
    Orlando, FL
    http://www.digitecinteractive.com
    Steve Radley replied 20 years, 3 months ago 1 Member · 1 Reply
  • Steve Radley
    June 26, 2006 at 5:18 pm
    I do have PAL black burst patched into the io.
