Activity › Forums › Apple Final Cut Pro Legacy › Capturing PAL footage in FCP (5.1.4) on Sony DSR-50 Deck
Posted by Benjamin Eshagpoor on June 9, 2007 at 3:44 amI’m trying to capture PAL footage in FCP (5.1.4) using my Sony DSR-50 deck. I’m not getting any video signal. I get audio and timecode, but no video.
Can anyone help me??
All the best,
Ben
Benjamin Eshagpoor replied 19 years, 2 months ago 3 Members · 5 Replies -
Jerry Hofmann
June 9, 2007 at 5:42 pmUse the “Easy Setup” for PAL DV to make sure the settings are correct, and also make sure that the video is checked on in the Clip settings of the log and capture window.
Jerry
Benjamin Eshagpoor
June 10, 2007 at 1:51 pmHey Jerry,
Thanks for the reply…unfortunately, that didn’t work. I should’ve mentioned that I’ve tried all the PAL settings in FCP, to no avail.
Same thing is still happening…I’m getting audio signal and timecode. Even with the video option checked in the clip settings panel of the log capture window checked, it still says “preview disabled”.
If you have any other suggestions, I’m all ears.
Let me know,
Ben
Jerry Hofmann
June 10, 2007 at 2:39 pmMight try trashing preferences… and then choosing the easy setup for DV PAL.. that deck isn’t common at all, and it may not work with FCP… I’ve never seen a sony deck that didn’t but…
You might also reset the PMU button on your motherboard. It’s near the batteries usually. it resets the power management to the FW bus and other things… must unplug power completely from your Mac first though.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Benjamin Eshagpoor
June 14, 2007 at 8:33 pmThanks, WSC2005! I’ll try it a bit later. Watch, I bet it works. This AFTER I had the PAL tape transferred to NTSC. Gotta love it!
Thanks again!!
Ben
