Activity › Forums › Apple Final Cut Pro Legacy › Capturing Long Play in FCP from Mini-DV
  • Capturing Long Play in FCP from Mini-DV
    Posted by Tacomabrian253 on January 22, 2007 at 8:53 am
    I accidently recorded in Long Play Mode. I recorded using a Gl-1.
    And I am having problems capturing the footage into FCP. I am using a JVC video deck(not sure exact model only that it is newer) to try and capture it. Please help me.
    Chris Poisson replied 19 years, 8 months ago 4 Members · 3 Replies
  • Jeff Carpenter
    January 22, 2007 at 1:02 pm
    Your best bet is to try and capture playing it from the exact same camera that it was recorded in. Most problems with LP go away if you return to the original camera.
    If that’s also not working I suggest hooking the camera up to the deck with firewire and make a tape dub onto an SP tape on the deck. Sometimes things play a little better when you’re just playing straight through and not trying to search for in-points and stuff like that. Once you get a copy (the video quality will be identical) you can log and capture the copy.
    Good luck!
  • Walter Biscardi
    January 22, 2007 at 1:31 pm
    [TacomaBrian253] “I accidently recorded in Long Play Mode. I recorded using a Gl-1.
    And I am having problems capturing the footage into FCP. I am using a JVC video deck(not sure exact model only that it is newer) to try and capture it. Please help me.”
    That’s not FCP, that’s your deck. If it’s a pro deck, it probably does not support long play mode. Our Sony DV/DVCAM decks do not support long play.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Chris Poisson
    January 22, 2007 at 2:39 pm
    Yes, dub the tape to SP, works fine.
