Activity Forums Apple Final Cut Pro Capturing LIVE to FCP X from JVC GY-HM750U
  • Capturing LIVE to FCP X from JVC GY-HM750U
    Posted by Kris Mcmullin on April 17, 2012 at 8:58 pm
    I apologize if this is a bit outside the thread, but I’m trying to configure FCP X to see my JVC GY-HM750U HD cam so I can literally press record on the camera and import/stream live into FCP X. I can’t find any settings that allow me to select my camera. When I go to import from camera, it only shows the webcam on my Mac Book Pro as being listed. Does anyone know the proper way to setup up a live capture into FCP X with a SDHC-based JVC HD Cam? Thanks!
    Dave Pickell replied 11 years, 11 months ago 3 Members · 5 Replies
  • Dave Brandt
    April 17, 2012 at 10:19 pm
    Hi.
    Are you connecting with USB or FireWire?
    To live capture you will need FireWire. I also found that you will have to start capture after you start record on the camera and stop capture before stopping the camera.
    I also found that using free run timecode makes fcpx happier.
    Macbook Pro 17″ i7 2.2 8GB
    iMac i7 2.8 16GB
    FCP 7 FCPX Adobe CS 5.5
  • Kris Mcmullin
    April 17, 2012 at 10:47 pm
    Thanks Dave. I connected my JVC camera via usb. I did not have a IEEE cable available. When I plugged it into the camera and then into the usb port, FCP X did not recognize anything. I went into the Import from Camera setting and all I saw was the web cam listed. I’m wondering if there is a setting within FCP or even on the Mac Book that would help FC find the camera. Either that, or I have to have that IEEE cable to interface to the Mac Book.
  • Dave Brandt
    April 17, 2012 at 10:59 pm
    I’m pretty sure you will need that FireWire cable to capture live. USB will only let you download previously shot clips from the cards.
    Dave
    https://www.solidmedia.ie
    iMac i7 2.8 16GB
  • Kris Mcmullin
    April 17, 2012 at 11:13 pm
    Ahh! That makes sense. I’ll be picking one up tomorrow to try it and hopefully it will work. Thanks so much for the quick response Dave!
  • Dave Pickell
    October 5, 2014 at 4:28 am
    Hi, did you get any luck? Tmho (tearing my hair out) … Fcpx shows my camera in the import window, all looks normal but the clip i thought i was ‘live importing’ never shows up…. Any help appreciated. Dave
