Activity › Forums › AJA Video Systems › Capturing Key and Fill Kona LHi Final cut Pro 5.1
  • Capturing Key and Fill Kona LHi Final cut Pro 5.1
    Posted by Andy Lynch on April 28, 2010 at 11:13 pm
    I am trying to figure out if it is possible to capture 1080i Key and Fill, simultaneously with a KONA LHi. I am running Final Cut Pro 5.1, and trying to capture the key and fill from an Avid HD Dekocast machine. I imagine that I would take the fill normally, through the input BNC on the back of the card. Would one of the other inputs on the pigtail be able to capture the key. Or would it be possible to take the key as component video at the same time?
    Andy
    Jeremy Garchow replied 16 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    April 29, 2010 at 11:03 am
    Unfortunately, no. You’d have to combine the streams later (capture twice) or combine in a mixer.
