Activity Forums Apple Final Cut Pro Legacy capturing JVC Decks to FCP
  • capturing JVC Decks to FCP
    Posted by Medwards07 on October 10, 2006 at 12:54 pm
    I recently purchased 2 JVC decks model # SR-MV50 and SR-DVM700. They are both listed as professional decks. When I try to capture in FCP it initially sees it but when I go to record or “capture now” it tells me there is no video signal.
    Apple says they are not on the list of approved decks yet and I have not found any drivers on JVC’s website. Does anyone have any suggestions or a digital work around. I am able to capture via S-video through a Data-Video converter but I hate to have a fairly expensive deck and still have to do it that way.
    Any suggestions would be greatly appreciated.
    Michael
    Michael Edwards
    Media and Graphics Director
    Victory Family Church
    http://www.lifeatvictory.com
    Medwards07 replied 19 years, 11 months ago 2 Members · 2 Replies
  • Thaxter Clavemarlton
    October 10, 2006 at 4:44 pm
    The JVC SR-MV50US is a DVD-R & S-VHS/VHS Dual Deck Recorder and Player.
    And the JVC SR-DVM700 is a miniDV and DVD recorder-player.
    The first one (MV50) simply will not be compatible as a capture device for FCP. The output of this unit does not go out the FW. The FW is an INPUT only.
    The second unit (DVM700) is a proud member of the JVC family of unreliable and incompatible miniDV combo decks.
    These units simply will not consistently work well with FCP.
    Here’s a workaround that won’t cost much money.
    I have had GREAT luck buying used miniDV “home video” camcorders and using them as spare “decks” and A-to-D-to-A video/audio converter “boxes”. I have bought MANY of these little gems at local Pawn Shops for UNDER $175 each (some for $99). The transfer quality in and out matches a deck, and the video/audio output (they all have S-Video outs) monitors great!
    AND… If you choose a SONY or PANASONIC camcorder (except for the earliest-built versions of the Sony VX1000), those two brands will ALSO playback perfectly any DVCAM-recorded mini DV tapes as well as DV SP and DV LP (yikes!).
  • Medwards07
    October 10, 2006 at 4:58 pm
    thanks for the info. Sounds like I should have saved the money and bought a DVD recorder and a few second hand mini DV cameras.
    I thought the DVM700 would be a decent deck for a reasonable price.
    Michael Edwards
