Activity › Forums › Apple Final Cut Pro Legacy › Capturing high rez jpgs from QT
Posted by Mort Korn on June 1, 2009 at 1:30 pmI need to grab a high rez still from a quicktime movie. It will be used for print so I need the best I can get. Any tricks?
John Fishbackreplied 17 years, 3 months ago 3 Members · 3 Replies
Jerry Hofmann
June 1, 2009 at 1:56 pmCan’t capture higher res than the QT movie has… but it’s a simple file/export/using QT conversion, then select still frame from the pop up there. JPEG’s aren’t the best quality, but png or tiffs might be best for this. Also might open the resulting still in Photoshop to clean it up if necessary.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Mort Korn
June 1, 2009 at 1:57 pmThanks for the quick response. If I have a VTS.VOB file open in streamclip what is the best way to export it or should I just grab a still in Streamclip?
John Fishback
June 2, 2009 at 2:47 pmCheckout this terrific program that will uprez your video still.
https://www.benvista.com/main/content/content.php?page=ourproducts§ion=photozoompro_1&gclid=CJjj9efp65oCFRYpFQodl3OdBQJohn
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
