Activity Forums Adobe Premiere Pro Capturing HDV via Firewire with Sony HVR-Z1U to Premiere CS4
  • Capturing HDV via Firewire with Sony HVR-Z1U to Premiere CS4
    Posted by Josh Spicer on January 18, 2010 at 4:55 am
    When i go to capture HDV video with the Sony HVR-Z1U to Premiere CS4 via Firewire it says the device is off line but when i switch the capture settings to DV it works fine but doesn’t capture in HD.
    I recorded st 1080i 60i
    and made the settings in premiere all match but i cannont get it to capture.
    can anyone please help me.
    Josh
    Philippe Verdoni replied 16 years, 4 months ago 4 Members · 3 Replies
  • Brian Louis
    January 18, 2010 at 6:07 pm
    Not knowing what OS you are using and what your computer specs are, this link may help you.
    https://help.adobe.com/en_US/PremierePro/4.0/WS1c9bc5c2e465a58a91cf0b1038518aef7-7f9aa.html
  • Jon Barrie
    January 18, 2010 at 8:50 pm
    Are u sure the camera is not set to downconvert. The light next to the FireWire port on the cam needs to be lit on hdv. Sounds like it’s set to dv.
    Get into the cam settings and change the settings to not down convert. (off)
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Philippe Verdoni
    January 19, 2010 at 10:38 am
    I also presently have this problem, it disappeared after I had reinstalled Premiere CS4 ( I am with Windows 7 32 bits) but it reappeared a few days after although I had not changed anything in my cam settings. Adobe says among other thinks the problem might be related to the PluginCache file and explains how to re-create this file:
    “Some problems may be caused by a damaged PluginCache file. To re-create this file, hold down the Shift key while choosing Start > Programs > Adobe Premiere Pro. Release the key when the Select Initial Workspace window appears.”
    In my case the procedure didn’t work; I don’t know which Windows 7 file is equivalent to the PluginCache file in Windows XP but I certainly have a problem with this file since Windows also stores the application preferences in it and I can see that some preferences that I correctly change are not saved when I re-open the project.
