Activity Forums Adobe Premiere Pro Capturing HDV in PP CS3
  • Capturing HDV in PP CS3
    Posted by Al Johnson on September 27, 2007 at 3:54 pm
    I’ve searched and saw some stuff about this, but nothing specifically about my question.
    So, I have a sony HDV camcorder here and I’m editing a show for a client. Until now I’ve just been setting the camera to down convert the HDV footage to DV on export, which works fine. However, when I tell it to export in HDV (the footage was recorded in HDV 1080i), I run into problems. Windows won’t recognize the camera and therefore I can’t connect to it in Premiere.
    Do I need a new driver or specific patch for Premiere? I’m running Vista currently.
    Thanks for any help.
    Mike Velte replied 18 years, 12 months ago 3 Members · 2 Replies
  • Kent Smith
    September 27, 2007 at 11:20 pm
    I had a similar issue with the Sony deck. Even though I had the deck set to HDV, it also needs the iLink down-convert to be turned off before PPro reconized the deck.
    Hope that may help.
  • Mike Velte
    September 28, 2007 at 10:24 am
    Also make sure you are in a HDV project.
