Activity › Forums › Apple Final Cut Pro Legacy › capturing HD
capturing HD
Posted by Quentin Block on March 7, 2007 at 8:11 pmHi-
I13 replied 19 years, 6 months ago 3 Members · 6 Replies -
Shane Ross
March 7, 2007 at 8:13 pmHow are you getting the signal into FCP? Routing it thru a DV camera or deck? If so, then it will only see it at DV resolution…because that is what those decks feed.
Shane
Littlefrog Post
http://www.lfhd.net -
Quentin Block
March 7, 2007 at 8:27 pmI am routing it through a canopus ADVC110. Do you think this is the problem?
Thing is that the firewire ports on the back of the HD box seem to be disabled (that’s what the cable company rep said…).
Otherwise would a direct firewier connection avoid this problem? -
Shane Ross
March 7, 2007 at 9:53 pm[Quentin Block] “I am routing it through a canopus ADVC110. Do you think this is the problem?”
Yes. The Canopus box sends out a DV signal. So that is what you are capturing. It cannot send out an HD signal.
You need an HD capture card to do this.
Shane
Littlefrog Post
Quentin Block
March 7, 2007 at 10:14 pmmaybe my new 24″ iMac with iMovie HD is equipped with the card that I need?
It seems to imply that I can capture HD… -
Shane Ross
March 7, 2007 at 10:22 pmNope…sorry. The iMac has no such card, and in fact, one cannot be installed. That is the drawback to an iMac. You can’t install capture cards. There are Standard Def ones that work for it (AJA I/O), they they don’t do HD. iMovie HD only works with HDV footage…captured via firewire.
If you can’t capture it via firewire, then you can’t capture it.
Shane
Littlefrog Post
13
March 8, 2007 at 4:51 amTo get HDTV onto you mac you will need something like the TVMini HD
https://www.miglia.com/products/video/tvminihd/index.html
