Activity Forums Apple Final Cut Pro Legacy capturing from Sony HVR-V1U
  • capturing from Sony HVR-V1U
    Posted by Jaime Vera on June 5, 2007 at 6:45 pm
    Can anyone help with some suggestions on why I can’t view footage when I try to capture from a Sony HVR-V1U camera? I can contol the tape however I get a preview disabled message across the log and capture window. I shot in DV mode with the same camera and my fcp settings are NTSC 48 kHz anamorphic and the device control is set to firewire ntsc.
    Thanks in advance.
    J
    Jeff Carpenter replied 19 years, 3 months ago 2 Members · 1 Reply
  • Jeff Carpenter
    June 5, 2007 at 7:01 pm
    Over in the HDV forum there’s a thread on June 3rd called “FCP won’t capture Sony V1U”
    It looks similar to your problem. Check out their solution and see if it’s the same thing.
