Activity › Forums › Apple Final Cut Pro Legacy › Capturing from a Digital Hi8 (DCR-TRV480E) to FCP?
  • Capturing from a Digital Hi8 (DCR-TRV480E) to FCP?
    Posted by Elaine Callahan on September 25, 2010 at 10:12 am
    Hello,
    I’m trying to digitize footage from my Sony Digital 8 Camera (DCR-TRV480E) to Final Cut Pro. I’ve seen blogs that tell me to just go into my Capture preferences and change my device control to ‘none’, and to just use Capture Now. But it’s still not even reading the camera. There’s no communication between the camera and the computer. I just keep getting an error message that says: Attempt to capture video without video device. Please select a video device in your capture presets and try again.
    Can anyone help?
    Danko Muzevic replied 14 years, 10 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    September 25, 2010 at 1:31 pm
    You should set your easy setup to DV for digital 8 cameras for starters.
    When you do, do you see video in the log and capture window from the tape? If not restart your computer with the camera connected and powered on. If you still don’t see the camera, try a different firewire cable and don’t loop it through a drive.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Elaine Callahan
    September 28, 2010 at 7:44 am
    Thanks Jerry,
    That helped. I’m up and running now!
  • Danko Muzevic
    November 22, 2011 at 7:26 pm
    what was the solution?
