Activity Forums Blackmagic Design capturing DV with Decklink: no monitoring?
  • capturing DV with Decklink: no monitoring?
    Posted by Michiel on June 21, 2006 at 12:15 pm
    When I capture DV material via firewire in FCP, I don’t get any video image on my broadcast monitor, only on the computer screen. I do get image on the monitor when capturing from digibeta, or while editing a DV sequence with the output set to decklink.
    Is this normal? Is there a way to preview DV while capturing on the monitor?
    Michiel replied 20 years, 2 months ago 2 Members · 2 Replies
  • Kristian Lam
    June 27, 2006 at 8:10 am
    Unfortunately no. When you capture via firewire DV, our products are not involved at all so you don’t get any previews. This is the same with HDV as well.
    regards
    Kristian Lam
    Blackmagic Design
  • Michiel
    June 27, 2006 at 11:44 am
    thanks. Yes I had found the same answer in another thread already, and now I also understand that it’s logical that there is no preview since everything is going trough the firewire and not trough the card.
    Still, my producer insisted that they used to be able to preview the video this way so I tried to think where i was wrong. Eventually found out that they were previewing the firewire signal on the tv set in our edit room and not any signal from the card on the broadcast monitor 🙂
