Activity Forums Apple Final Cut Pro Legacy Capturing DV footage – use DV compression ?
  • Capturing DV footage – use DV compression ?
    Posted by Ace Billet on September 8, 2005 at 8:33 am
    Client provided me with a MiniDV tape with some footage.
    I need to do Color Corrections on it (Using AE)
    I was wondering (for general knowledge as well) is there any differnce
    if I capture the footage using 8bit, 10bit or DV capture presets ?
    I did them all, compared frames but couldn’t find any noticable differences.
    (Maybe because the original footage looks like cat litter). Hmmmmm.
    Are there specific regions I should pay attention to ? Skys ? Grads ? Reds ?
    cheers
    ace
    Ace Billet replied 21 years ago 2 Members · 3 Replies
  • Ace Billet
    September 8, 2005 at 8:36 am
    Let me add that usually I capture raw footage using DV prests,
    But this is a 3minute that has some treatment to it and
    I didn’t want to get any DV artefacts.
    cheers
    ace
  • Shane Ross
    September 8, 2005 at 9:41 am
    You gain nothing my capturing DV at 8-bit or 10-bit resolution, other than increase ability to green screen and the fact that any graphics you add to the project will look better. In fact, if you capture DV at 8-bit or 10-bit you are slightly COMPRESSING the image. The only true lossless way of capturing DV is via firewire using the DV/NTSC (or PAL) presets. Capturing 8 or 10-bit for color correction won’t improve things, I’m afraid.
    DV is, by nature, compressed 5:1 in the camera. If the artifact is on the tape, it will be on the captured footage. Garbage in, garbage out as the saying goes.
  • Ace Billet
    September 8, 2005 at 11:09 am
    Thanks Shane, just what I thought.
    cheers
    ace
