Activity Forums Blackmagic Design Capturing doesn’t stop at end-time
  • Capturing doesn’t stop at end-time
    Posted by Sascha Teuber on February 7, 2011 at 4:41 pm
    Hi!
    I am having the problem that the capturing doesn’t stop at the given end time. I have to press ESC and say don’t delete the file. That’s not pretty.
    I am using:
    Windows XP Pro 32 Bit SP3
    Decklink 7.9.3
    Thx!
    Sascha
    Joshua Helling replied 15 years, 6 months ago 2 Members · 1 Reply
  • Joshua Helling
    February 16, 2011 at 7:17 pm
    Odd…what app are you using to capture? In most apps you are either capturing a timecode range or crash capture. If you’ve got a timecode marked clip (with a timecode stripe that is not broken) then the capture be it in Media Express 2 or Premiere Pro will stop when the clip has finished capturing.
    If you simple click to capture in the app it will not stop just because the tape runs out.
    Are you using a different app that supports a “capture time limit” function?
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
