Activity Forums Adobe Premiere Pro capturing audio mini plug, right channel only. ideas?
  • capturing audio mini plug, right channel only. ideas?
    Posted by Rick Neely on February 23, 2018 at 4:10 pm
    Hey guys,
    quick issue I’m having–
    have an older macbook pro with 3.5 mini jacks (in and out) running premiere pro on a Mountian Lion OS. trying to capture audio from an old, OLD audio cassette recording. My setup is simple:
    tape deck with RCA stereo out (L/R) to mini 3.5 stereo plug
    plug connects to macbook in jack
    In premiere pro, adjusted settings for line input and can capture audio in a sequence by clicking on the little mic icon in the timeline.
    The problem,
    audio only records to the right channel, not left.
    I’ve tried a few cables and alternated the jacks in the tape machine (machine audio level readers show l/r playback fine), but no luck. Also checked the audio mixer, and other things to see if I assigned right channel capture only. All seems fine (stereo capture).
    I’m thinking it’s either a software or system preference setting, or (gulp) the in out jack will no longer can capture stereo left in.
    Any advice on things to check? Thanks in Advance.
    Rick
    Rick Neely replied 8 years, 7 months ago 2 Members · 2 Replies
