Activity Forums Adobe Audition Capturing audio from Flash Player
  • Capturing audio from Flash Player
    Posted by Richard Hubbs on January 17, 2012 at 4:13 pm
    I use Adobe Audition for my audio work. I was wondering if it is possible to capture audio which is embedded into a website flash player using the programme to get a clean sound – i.e. the source which comes from the speakers, rather than just using the mic to capture the 2nd hand sound coming from the speakers.
    Thank you for any advise.
    Steven Talley replied 14 years, 7 months ago 2 Members · 1 Reply
  • Steven Talley
    January 18, 2012 at 3:29 pm
    Depending on the sound card or chip used in your computer you can tell the audio mixer to record any sounds that are played back through the machine in real time.
    Open the audio mixer and select wave, stereo mix or audio out to be recorded then open Audition to record.
    You may need to select the audio out under preferences in Audition also. It all depends on what your computer audio hardware is capable of.
