Activity › Forums › Apple Final Cut Pro Legacy › capturing 4 audio channels without mixing them into 2 audio channels?
  • capturing 4 audio channels without mixing them into 2 audio channels?
    Posted by Kibbyproductions on May 10, 2006 at 6:07 pm
    I just converted form using Matrox on PC to FCP on the G5, So please bear with me. I’m capturing from a Canon XL1 via firewire with no problems except that FCP will allow “Only” the 1st 2 audio channels or “Only” the 2nd 2 audio channels to be captured. It will allow all 4 channels to be captured “Only” if the 4 channels are Mixed into 2 audio channels which defeats the use of wireless mic’s as a secondary audio inputs during shooting. I’m sure there’s an easy way to fix this but I can’t find it anywhere.
    Bill Kelly replied 20 years, 4 months ago 3 Members · 2 Replies
  • Kevin Monahan
    May 10, 2006 at 7:19 pm
    I’ve found that a 2 pass capture is the only way around this.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
  • Bill Kelly
    May 10, 2006 at 11:05 pm
    Go to your Sequence Setting>>Audio Outputs and set it to 4 channels rather than two. As long as you have 4 channel out from your deck/camera and capture card (Kona LH has this), you should be all set.
    Make sure in your log & capture window, in Clip Settings, that you enable all 4 channels to capture.
