Activity Forums Apple Final Cut Pro Legacy Capturing 30p HDV with Decklink HD Extreme
  • Capturing 30p HDV with Decklink HD Extreme
    Posted by Enrico Lappano on February 16, 2011 at 7:09 pm
    I am capturing 30p HDV footage from a Canon XH-A1s and recently installed a Blackmagic Decklink HD Extreme to my Mac Pro. Now I have a number of new options to capture with. I will be converting it later to ProRes and mixing this with 7D proRes footage on a 1920×1080 30p ProRes sequence. Normally my Capture Preset was simply HDV. Should I be changing that setting to Blackmagic HDTV 1080p 59.94 (8 or 10 bit?) or something else?
    Along with this, the Device Control Preset used to be Sony HDV Firewire. Should that setting also change accordingly or not?
    The Video Playback is set to Blackmagic HD 1080p 59.94 (1920×1080).
    I appreciate any help on this question.
    Enrico Lappano replied 15 years, 7 months ago 2 Members · 2 Replies
  • David Roth weiss
    February 16, 2011 at 7:25 pm
    [Enrico Lappano] “I will be converting it later to ProRes and mixing this with 7D proRes footage on a 1920×1080 30p ProRes sequence. “
    Seems to me you should be capturing as Prores 1080p30.
    Why would you capture as anything else and then transcode?
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Enrico Lappano
    February 16, 2011 at 9:58 pm
    The 7D clips are being captured as ProRes 1080p 30. Does that also apply to the HDV footage from the
    XH-A1s?
