Activity › Forums › Adobe Premiere Pro › Captured video problem
Posted by Martin Mundy on June 16, 2008 at 4:41 amTo All,
I have a problem with captured video the total length of the event is 55 mins. After I capture the video in PPCS3 I only get about 15 – 20 mins of footage. Any help is much appreciated.
Martin Mundy replied 18 years, 3 months ago 4 Members · 8 Replies -
Ann Bens
June 16, 2008 at 8:19 amAny chance of you harddisk being FAT formatted instead of NTFS.
FAT does not allow you to capture more than 4 gig which is about 20 minutes. -
Mike Velte
June 16, 2008 at 10:52 amI am betting on broken timecode on the tape…your footage is there, but finding it can be tough. FF to the end of the tape visually, then rewind.
Martin Mundy
June 16, 2008 at 3:13 pmAll my HD’s are formatted NTFS. I captured from camera using a firewire cable. I captured all my video from the same event from a different tape. All the video from these clips work fine using them in the timeline. The thing that is puzzling, I can open the video using media player and watch the entire event.
Martin Mundy
June 17, 2008 at 4:49 amThanks for all your help, figured out the problem, was the MainConcept codec, the avi file was using a DVPRO HD codec. Uninstalled the HD plugin and fixed all.
Mike Velte
June 17, 2008 at 11:02 amNo, FF your camera and verify that you are at the end of the tape, then rewind a bit to see the footage you missed. Finding the break can be tough.
Martin Mundy
June 19, 2008 at 12:57 amMike,
Thanks for your help, that answered another question on another project. This problem had to do with a mainconcept HD codec.
