Activity Forums Apple Final Cut Pro Legacy captured in fcp6/need to work in fcp 5.0.4
  • captured in fcp6/need to work in fcp 5.0.4
    Posted by Mark Fason on August 29, 2007 at 9:32 pm
    I’m running fcp 5.0.4 on a Dual 2.7Ghz G5, with an AJA Kona card. I’m going to be recieving a project that was captured with fcp 6 and was wondering if i’ll be able to use that media in a 5.0.4 project.
    thanks.
    Matt James replied 18 years, 8 months ago 3 Members · 2 Replies
  • Tom Wolsky
    August 29, 2007 at 9:40 pm
    The media should not be a problem, unless it’s in a codec that not supported by FCP5.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Matt James
    August 30, 2007 at 7:21 pm
    You will not be able to open the FCP 6 project in 5.0.4 however. Therefor if you need to have the project info, like the bins or any sequences, you can have the FCP6 Project exported out as an XML file (version3 or 2) and import that into FCP5.0.4 no problem.
    The media will be just quicktimes that you can use in any FCP version, that your Quicktime version will support. I.E.: older versions of QuickTime will not play the newer codecs.
    Matt James
    Freelance FCP Editor
    Denver, CO
