Activity › Forums › Apple Final Cut Pro Legacy › Captured files have -a, instead of -av
  • Captured files have -a, instead of -av
    Posted by Derek Barbee on February 9, 2010 at 7:43 pm
    I’ve noticed that sometimes when my files are interrupted in capture, they will have the suffix of -av. If a file finishes capturing normally, however, it removes that suffix and just gives it the name I type into the Capture settings at Log and Capture.
    Recently, however, it started just putting -a at the end of the files, and not removing it, even if everything captured correctly. If I attempt to remove the -a from these files, or rename them in any way, they show up just as audio when I bring them into Final Cut. If I don’t touch them at all, they have the video, but if I attempt to modify them in any way, or move them, they just show as audio (even though they are massively sized files, and should have video in them).
    I’ve looked at my Capture settings in all the places I can find, and it looks as though it should be capturing both audio and video. I don’t know why this suffix has started permanently appearing, especially as -a and not -av.
    Does anyone know why this would be?
    Jerry Hofmann replied 16 years, 7 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    February 10, 2010 at 10:31 am
    How is your drive formatted? It shouldn’t capture the way it is in the first place I don’t think.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
