Activity Forums Apple Final Cut Pro Legacy captured clip from Sony NXCAM will not open
  • captured clip from Sony NXCAM will not open
    Posted by Weymouth Kirkland on October 9, 2010 at 10:43 pm
    I captured a clip from the NXCAM, which uses the AVCHD MPEG2 SD format. It shows in the capture scratch as a .mov, but will not import to fcp. I get: “File Error: 1 file recognized, 0 access denied, 1 unknown”.
    Anyone have a clue as to how I can salvage the clip of a wedding ceremony? The other clips captured as Apple ProRes 422.
    Shane Ross replied 15 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Steve Eisen
    October 10, 2010 at 12:49 am
    You need to use log and transfer
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Shane Ross
    October 10, 2010 at 1:42 am
    You need to update to 7.0.3, THEN use log and transfer. previous versions had issues with SD and that camera.
    Shane
  • Weymouth Kirkland
    October 10, 2010 at 2:50 am
    I did have 7.0.3 installed. I videoed using1080/60i FH recording format.
  • Shane Ross
    October 10, 2010 at 6:37 am
    Then use Log and Transfer. You can’t use the files directly from the camera. They need to be converted.
    Shane
  • Weymouth Kirkland
    October 10, 2010 at 8:06 pm
    oops, it looks like I updated to 7.0.3 the day after transferring this clip. And I formatted the card that contained the footage. Any way to salvage the footage from the unrecognized .mov file?
  • Shane Ross
    October 10, 2010 at 10:37 pm
    [Weymouth Kirkland] “And I formatted the card that contained the footage”
    WHAT? Really? Why? Why do people NOT save a backup of their footage. Do you throw tapes into the garbage after you capture? Erase and then reuse them? Hard drives aren’t bullet proof. They can fail Mistakes can happen. ALWAYS backup your footage…always. Watch this tutorial for the proper way of doing things tapeless:
    Tapeless Workflow for FCP 7 Tutorial
    [Weymouth Kirkland] “Any way to salvage the footage from the unrecognized .mov file?”
    How? If the file is unrecognized, how can you salvage anything from it? If VLC player doesn’t see it, then you are hosed. If it does, then you can get perhaps screen capture software or something. But I’m 95% sure that you are up a creek without a paddle.
    Shane
  • Weymouth Kirkland
    October 12, 2010 at 4:17 am
    Yes, I jumped the gun moving from my PD-150 to the HXR-NX5U and just assuming I could point, shoot, and capture/transfer. Not too smart. Now I’m left with a “.mov” file that I cannot seem to open with Quicktime Player, FCP, HandBrake, vlc, or VoltaicHD, a file that shows as a 32.8 gb file in my capture scratch, a file that Quicktime Player says: “The file is not a movie file”. There must be some way to open this file. Dang!
  • Shane Ross
    October 12, 2010 at 7:47 am
    The camera is really that simple…if you do things right. You have to back up the FULL CARD STRUCTURE, not just certain files. And it can be a drag if you have an older version of FCP. Sony took the AVCHD standard (HAHAHAHAHA!) and changed it…added LPCIM audio that messed up import times. Added custom timecode to the camera but didn’t tell any NLE maker where to find it. It took a guy at Divergent to find it and allow it to be added to the converted files with CLIPWRAP 2.
    Camera makers LOVE to make new cameras, and new codecs, and leave NLE makers in the dark. Happens so often I lost count. NEVER buy the new new new cameras just on the market…wait to make sure the NLEs catch up.
    Now they have…so the NXcam cameras are fine.
    Shane
