Activity Forums Blackmagic Design Capture /workflow Question – Digi to DVCPRO-HD
  • Capture /workflow Question – Digi to DVCPRO-HD
    Posted by Gunleik Groven on January 3, 2006 at 2:49 pm
    Hi!
    Because of the PCI-X to PCIe issue, I’ve settled on not going with the Studio for now… -;(
    But: I will have to film in digibeta and deliver in 1080i or 720p.
    Where, when and how would you uprez. Is it possible to capture SD 16:9 as HD through analogue? (f.ex. dvcpro hd?)
    Or is there a better way?
    Gunleik
    Gunleik Groven replied 20 years, 8 months ago 2 Members · 2 Replies
  • Sean Oneil
    January 4, 2006 at 10:19 pm
    You shouldn’t capture it as HD. You should capture and edit in SD, then do the conversion when you’re ready to finish. Unless you have a ton of HD graphic files to work with, it doesn’t make sense to do your work in HD.
    If the footage has 3:2 pulldown on it, I would suggest capturing and editing at 24p Uncompressed SD. This will make the upconversion much easier when the time comes and you won’t need a Teranex to do it. You can use Final Cut, After Effects, or any other software based scaler and get good results.
    Sean
  • Gunleik Groven
    January 5, 2006 at 1:23 pm
    Gunleik
