Activity Forums Apple Final Cut Pro Legacy capture with cards
  • capture with cards
    Posted by Rui Carvalho on February 24, 2010 at 10:11 am
    good morning
    when I record with my camara sony hdv to compat flash card in it creates dv video files and when i import for final cut pro he needs to make render of audio why? someone help me? I record the sound to 48khz and the timeline is also 48khz because I render?
    tanks
    PPX
    Rui Carvalho replied 16 years, 7 months ago 2 Members · 6 Replies
  • Jerry Hofmann
    February 24, 2010 at 2:18 pm
    You are actually recording DV? Is it PAL? If so when you import these files to FCP, and you create a new sequence to edit with, don’t you get the dialog box that asks you to conform the sequence to the clip’s properties? When you do, you should just click yes, and all should not have to render.
    This presumes you’re using FCP 6 or 7 though. Are you?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Rui Carvalho
    February 24, 2010 at 6:53 pm
    yes i am recording dv pal and i am using final cut seven whit all updates.. no when i trie to put de videos in sequence dont show any message but audio needs render i dont understand. can you help me please
    tanks for your reply
    PPX
  • Rui Carvalho
    February 24, 2010 at 7:00 pm
    I think I discovered the source of the problem but do not know how to solve it my camera recorded the audio rate 48khz but the audio format is 32 bit floating point and in the sequence i have 16 bitinteger. in sequence I cant put 32 bit floating that does not exist.. can i change the format and write to 16 bit integer in my camara? tanks
    PPX
  • Jerry Hofmann
    February 24, 2010 at 7:37 pm
    Well, you could export the audio files and make them all 16 bit…. i.e., it amounts to doing the rendering all at one time.
    But that said, could you select a clip in your browser, then type cmd+9 to reveal it’s properties, and post exactly what they are? Seems to me that your problem could be solved that way. Cameras don’t record audio that FCP can’t use directly as far as I know.
    Jerry
  • Rui Carvalho
    February 25, 2010 at 2:17 pm
    type – clip
    creator – quick time player
    size – 209 mb
    tracks – 1v, 2a
    vid rate – 25 fps
    frame size 720 * 576
    compressor – dv pal
    data rate – 6.9 mb/sec
    pixel aspect – pal – ccir 601
    field dominance – lower
    alpha – none/igone
    composite – normal
    audio – 1 stereo
    audio rate – 48.0 khz
    audio format 32 bit floating poit
    tanks a lot
    PPX
  • Rui Carvalho
    February 26, 2010 at 9:18 am
    Mostrar romanização
    I have another doubt that I think I can help .. in final cut pro every time I put text on the timeline created in the final cut had to make render now formatted the computer and when I use text not need to render, there is any menu, preferences, cache, that from time to time we must erase to final cut be faster? tanks
    PPX
