Capture Trouble
I have FCP 4.5 on a G4 dual-800 and trying to capture video from my DSR-11 deck. Never had any issues until now. I have timecode and can control the deck in the Log & Capture window but no picture. When I open FCP I get the message: Unable to locate the following external devices: Apple Firewire NTSC (720×480). Under My Computer the deck shows up under Hardware/Firewire. I made sure all my settings are correct. I took the deck and same firewire cable & hooked it up to my laptop (Tiger 10.4.11 with FCP 4.5) and it works fine. For what it’s worth I recently loaded Tiger on the G4 and downloaded all the updates so it should be the same as my laptop. One other thing: When I open Toast 6 Titanium and then turn on the deck Toast shuts down. If I have the deck already on and click on Toast it pops up for a second and shuts down. I just used this last week with no problem. Is it possible that loading Tiger did something? I appreciate whatever help you can pass on. Thanks!
