Activity Forums Apple Final Cut Pro Legacy Capture to Sony Dvw 500p “Unable to lock servo on deck” + a ton of TC problems
  • Capture to Sony Dvw 500p “Unable to lock servo on deck” + a ton of TC problems
    Posted by Gunleik Groven on February 13, 2007 at 4:01 pm
    Hi.
    Struggeling to lay back some work to digibeta through the DVW 500P and with a decklink card.
    Two problems.
    1.
    Striping the tapes.
    When I stripe them from the deck, the TC suddenly goes haywire and jumps all over the place
    when I try to black them from the “edit to tape” window, it looks better, except from the fact that I cannot get the TC to start where I want (usually it starts around 15-20-23’ish hours somewhere. I need it to be at
    00:00:00:00
    Or more ideally:
    I’d like to start at 23:58:00:00 and insert @ 00:00:00:00
    I’ve set the device control preset to LTC + VITC and the pre-roll to 10 secs (I’ve tried up to 30 secs)
    My tapes are all new btw.
    Finally I managed to stripe 6 minutes (which is just about enough), but then I get the
    “Unable to lock servo on deck” message.
    I would happily read the bleeding manual, if the rental house hadn’t decided that the manual was not to come with the deck…
    Anywhere I can DL it as a pdf?
    I have upgraded the declink software, with the exact same symtoms as the result.
    Any ideas appreciated!
    I can also be reached privately at gunleik (at) vulture (dot) no
    Cheers!
    Gunleik
    Gunleik Groven replied 19 years, 6 months ago 3 Members · 4 Replies
