Activity Forums Apple Final Cut Pro Legacy Capture sync error
  • Capture sync error
    Posted by Kevin Means on July 20, 2007 at 8:19 pm
    Hi all…
    I have had a problem with FCP since version 5. I just upgraded to version 6 and hoped it would go way but it’s still there. When I capture footage (analog or DV) the capture process goes bad. It happens about 50% of the time and is more common on longer clips. The capture window looks fine, but when I play the video back on the timeline or as an independent .mov file, the video and audio are messed up.
    The footage starts acting like it’s in fast-motion, and there’s a “clicking” sound to the audio. It doesn’t always happen, but it happens enough to be a pain. If I restart FCP it often stops happening. It’s definitely associated with the record phase – the clips are being recorded that way – even though the capture process appears to be normal.
    Dual 1.8 Gig G-5, 2 gigs of ram – 400 gig HD, (with 80 gigs full)
    Any ideas?
    Kevin
    Kevin Means replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
