Activity › Forums › Apple Final Cut Pro Legacy › Capture settings weirdness
  • Capture settings weirdness
    Posted by Erik Naso on June 10, 2008 at 6:55 am
    Ok. I’m feeling a little needy today. But here goes.
    I have a Panasonic deck inputed via SDI into Kona LH. Using serial to USB for deck control. I am running a G5 with FCP 6.0.2 QT 7.3.1
    My settings are:
    Sequence DV NTSC 48khz
    for capture Kona LH 525 29.97 DV
    Device USB serial. I made this setting
    Playback Kona 525i29.97 8 bit
    these are for a current project. I have a DVCpro50 easy setup with the same issue.
    I was setting up my project and making a new easy setup for this deck with SDI out. Every time I exit log and capture then reopen to capture again I get no video signal in the window. I have to go to the settings tab in log and capture and change the settings to anything other than what I had setup like a HD setting then go back to my original setting then the video will come back. I might have to do this a few times for it to finally take. Still if I exit capture then return its gone again. Any ideas how can I fix this?
    I am getting deck control and timecode just no picture or sound. It worked well with the Firewire output but I want this to work with SDI for other projects.
    Thanks.
    Erik
    Erik Naso replied 18 years, 3 months ago 1 Member · 2 Replies
  • Erik Naso
    June 10, 2008 at 3:28 pm
    maybe i should have posted this in the Kona forum?
  • Erik Naso
    June 11, 2008 at 1:46 am
    I fixed the issue. here is the fix for future reference.
    Delete the Kona Preferences:
    a) Go to: /library/preferences and delete
    com.aja.KonaPreferences.plist.
    b) Go to: /users/username/library/preferences/ and delete
    com.aja.KonaControlPanel.plist.
    c) Reboot and then reset the Kona Control Panel parameters.
